uncovered the car & paint is clean. but I water less washed it anyway. then I clayed the paint & made sure everything was dry. the temp in the garage was 55 degrees(outside temp was 40ish). for some reason I'm finding the polish is really grabbing when I go to wipe it off. also it's grabbing a little when I apply it. I had one yellow foam pad start coming apart on me. pad did not get hot but when I took it off the face plate was pretty warm. It was a used pad and maybe I didn't have it on perfect. I'm using a rupes 15 with yellow pads & their fine polish. I used 4 to 5 dots of product the first time & them maybe 3 to 4 dots after. machine was between 4.5 to 5 setting. was the temp to cold & that's why it was hard wiping off ? or is that the nature of using a polish ? I don't remember ever having issues wiping off polish. most the time I use a AIO & then top with a wax. any suggestions to what I may be doing wrong ? thanks
Carlo
Carlo
