I have a few questions about detailing a Black 2015 Silverado I just bought.
1. I bought it a month ago and it is winter here in NY so I am sure I am going to find spots that can use some touching up once spring rolls around. From what I can see now there a couple light scuffs and scratches. I was thinking about using 3D Speed to do a one step polish. Would that be a good product/process to use on a 2.5 - 3 yr old vehicle?
2. There was a spot that had a drop of dried on concrete on the fender that the dealer couldn't get off without damaging the paint so they repainted the fender. Is it ok to polish that fender and use ironX on it since it will have been just painted 5 months previous?
3. What steps should I do before and after doing the one step polish? I am still debating if I will do a ceramic coating or just a sealant topped with wax, so wasn't sure if I need to use ironX before claying or if claying will be good enough. Also, do I need to wipe down with an IPA after polishing, before adding the sealant/wax?
4.The truck was waxed at the dealer. Should I just wash with regular shampoo or should I use something like Meguiars wash plus to remove that wax before polishing?
5. There is a spot that has some what looks to be green paint transfer (about a 1/2" wide section maybe 4" long on a narrow section of the rear bumper where the corner step is). Will using the 3D speed with the DA take that off? or should I do something to remove that by hand so it doesn't get into the pad?
6. I can just spot polish if the whole truck doesn't need it right? For example if there is a scratch in the middle of the door can I just go over that small area or should you really do the whole panel? I am totally new to polishing if you can't tell. lol. I just didn't know if it would be obvious that that spot was polished and not the rest of the door.
7. I have seen a couple youtube videos where people are claiming that the Harbor freight DA is just as good of a polisher as the PC 7424. Any experience with the HF DA?
