Poll: Do you wash after claying?
spewking
Member
I have starting using the nano skin so i guess the reason for the second wash would be to remove any contaminants released from the claying that remain on the car?
The detail spray or other lubricity agent would also be in the car to some degree, but that would be taken care of by the polishing.
What is your opinion on the wash after claying?
Thanks.
After I use nanoskin anything with Glide yes I wash again quickly before the polishing stage.
I use the Nanoskin Wash Towel for my claying. It solves the problem of washing the car after a clay. It savesa huge amount of time and you do not need any lube. The soap suds and water are the lube.
I keep my vehicles waxed, sealed or coated. The clear stays smooth therefore I have no need to use Nanoskin
Sent from my SM-G955U using Tapatalk
In ideal situations:
Wash the vehicle in cool weather in complete shade.
Leave vehicle wet, rinsing as needed to keep it wet.
Use your choice of claylube and clay media.
Rinse vehicle once more after every panel has been clayed and then towel dry.
Proceed straight to lsp. [or compounding/polishing if that's what the plan is]
I have great results with those steps 95% of the time. [5% chance the clay/clay towel actually marrs the paint, but IME that's pretty rare]
Same here but I will still use the nano skin stuff in tandem with a traditional clay bar. I love their products and in most cases work far better than clay. I use mostly the fine grade which doesn't even mark up black paint.
Bingo.^ That's how life is for my vehicles :)
I have the medium sponge and mild pad plus shock and glide. If I choose to clay, iron removal first, clay wash....lots of suds
Washing after claying seems like it would be equal to brushing after flossing. Just thinking out loud...
After using an iron remover, for me a wash is essential
I really don't get this analogy at all. Sorry. And btw look it up brushing first or flossing first is irrelevant as long as it gets done daily
My method is Iron X, rinse, foam, rinse, hand wash, rinse, clay/nanoskin and wipe down, then proceed straight to compound/polish.
Full Wash-rinse--IronX--rinse--Nanoskin block with Rinseless wash as a lube--rinse--dry--polish. If using a rinseless wash as a lube I see no need to re-wash.
No, not if I am using a rinseless wash as my lube which is what I typically use.
Yes, if I use a wash "soap", but that's pretty obvious.
Interesting discussion.
Would rinse, (optional soap foam, then rinse) iron x, rinse, clay/clay mitt, then full wash be an efficient order of things?
Would you be worried with this approach the iron x particles may remain after the rinsing and then get swirled and scratch the paint? Would use the WW for lube so such could help remove dirt and particles.
Thanks.
ONR is the lube I use, which is why I skip the wash after clay bar.
