polycharger dosing, help????
corolla619
went to start my dosing, put the dropper in and went to fill it up. well it only filled half way? this is the h20 polycharger and am gonna mix it with meguiars detailer, it says 1 per 4oz. so by filling the dropper half way, is that 1 or do i have to fill the dropper up the whole way to acheive 1?
Empty dropper, squeeze dropper and insert in bottle and release, remove, what you have is one "dose".
Ditto. However, if you have a hole in your bulb or for some other reason it isn't allowing you to fill the whole dropper, then you'll have to eyeball it. It isn't an exact science and if you put in a little too much or too little then you aren't going to get any explosions or anything. ;) Just make your best guess and then enjoy the results. Adjust the does as needed based on those results.
what i am getting at is when i squeeze the bulb it only fills it up half way so i was wondering if that was one dose. just got off the phone w/lynn matthews over at autopia and she talked to the chemist. one dose is only half the tube which is what you get when you squeeze the bulb.
so to clear things up, squeeze the bulb, what you will get is a half way point on the dropper which=one dose.
if you check autopia's site, there now are actual dosing instructions, this all obtained from my phone call w/lynn, she said she was updating it for this soul purpose.
all thanks to me lol haha.
