Jimmie said:Yes a sealant can be used as your final protection. You do not need to top it with wax but you can.
killrwheels@autogeek said:sealant = synthetic wax
Typically, sealants require at least 30 minutes vefore you can wipe it down. You can apply it evenly, and thin, and then go a second coat to ensure good coveragematteo86 said:Im using a black/grey LC pad.. is that the correct pad to apply EX-P.. or should i use my wax applicators by hand. I dont mind doing it manually just want to be sure that the right one for the machine.
Also if someone has tips on using it like apply evenly, and how long to wait before wipe off?
Thanks
Z06-Goose said:Typically, sealants require at least 30 minutes vefore you can wipe it down. You can apply it evenly, and thin, and then go a second coat to ensure good coverage
Yes; I honestly feel WG would have lasted just as long if not longer. I may trade it off despite how well it looked on the mustang.P1et said:From personal experience I've found that EX-P looks good, but it doesn't last to save your life. Horrible!!!
