I havent used an AIO yet, so what would be a good speed to use PB Polish and Sealant? I plan on using it with a 5.5" white LC Pad. Then I plan on applying some PB Liquid Natty Blue with gray LC Pad at speed 1 or 2.
Thanks:xyxthumbs:
I always start at around a 3 and then kick it up as needed. There isn't really a set speed you have to use a product at. It is very relative to what you are working on and the results you are getting. You may be able to do what you need at a 4 or 5. No sense in going faster if it is working fine at a slower speed.
Thanks there OCD. After I saw your results on that White Toyota, I decided to break out and try out the PB Polish and Sealant I got for Christmas. Hopefully if things go right this weekend, I hope to do the wifes car.
Thanks again :dblthumb2:
