angrypressmn
- Apr 9, 2007
- 53
Newbie I'm ordering PB detailing kit( black color car), is it also a good idea to order either PB-ex or PB-exp sealant which do you perfer ?
For a black car I would use the EX. More of the carnauba look.
Agreed. EX has carnauba and amino resins in it to give the carnauba look while maintaining sealant durability. Top EX with a wax and / or Optimum Car Wax and you'll have a very nice glow. I mention the OCW because you can use it after washes to maintain the look, slickness and durability of the EX and Natty's. It is very simple, after you dry, you can wax with OCW in about 5 minutes- spray on, wipe off. Done..
Does PB spray & gloss(included in PB kit I'M ordering) come into play anywhere in this process? Thanks in advance just trying to learn as much as possible so I can take advantage of 15% sale b/4 ends
You can definitely use the Spray and Gloss as an alternative to the OCW. The only difference is that Spray and Gloss will not add any protection, but it will increase the slickness and obviously will add gloss. Since S&G is coming in the kit you may not need the OCW at this point in time. Plus Optimum is re-doing the OCW so you probably should wait until the new version is out.
As I said in the other thread, a mist of the S&G will help with the application of Natty's. It's also great to use during or after drying your vehicle. Just be sure to mist and not soak the surface, if you use too much it may streak some. It also has a very pleasent scent.
