Pockets@PoorboysWorld
- Jul 22, 2009
- 835
Got a chance to wash the trucks today at work and decided that I would show you all how well Spray and Rinse works even on a badly neglected rim's. Sad to say that it's my own truck
but onto the pictures
Here is a shot of the rim before anything done to it no previous washing
Here it is after being pressure washed
Even after being pressure washed there is still a lot of crud and baked on dust
Center Hub Before
Spray and Rinse liberally applied (remember what it does not touch it can not clean) I also sprayed the barrels of the rims
After dwelling on the rim for around 5 mins or so (still on the rim not rinsed off yet)
Rinsed away with absolutely NO scrubbing NO rubbing and NO brushing! Rim is clean as can be
Center hub after (you can also catch how clean it got the barrels that were black before)
Just something funny can you guess which letter was at the bottom of the rim and had all the Spray and Rinse drip over it? =)
This was all done with a pressure washer but you can get the same results using a decent pressure hose.
Simple and easy to use!
-Chris
P.S. - I did not bother to clean the white letters because I am getting 35" Toyo Open Country M/T's put on tomorrow morning =)
Center Hub Before
-Chris
