I use a 10X10 Ez up and put up by myself. Takes a little bit but you can do it. Like Ed said. One corner at a time. I've been meaning to ask Cosmin how he puts up his 10x20.
I don't know how you pull it apart far enough by yourself to even be able to work on the corner. I apparently am EZ-Up challenged.
Grab the inner angles closest to the center and while pulling apart, drag the tent back slightly. This will open the tent some so you can now get underneath the tent. Find the center post and slowly push up until the tent opens. Now you can work one leg at a time. Always try setting up so you can drive the car under the tent.
what should you expect for one ofthese and what size do you need? I'll be doing a lot of work outside and would much rather have the car shaded (obviouslylol)
