Many of you have permanent and awesome lighting set ups, but as a weekend warrior, such is not feasible for me.
I am looking for a portable lighting solution. I like the stands so the height is adjustable. Lowes has a 2 light portable on a stand with 2 100 watt bulbs with 10000 lumens output. It looks cheap and likely won't last.
Can you recommend a sturdy portable light, e.g., brand and where to buy? For a standard garage, how much wattage/lumens do you recommend?
Lastly, do you have an opinion about halogen or going with LED? I guess the LED benefit is low(er) heat output, but the output is much less (lumens) and does not appear adequate for a standard garage with typical overhead lighting.
Any comments appreciated.
Thanks,
David
Thanks,
David
