Does the Porter Cable 7336 6" HD Random Orbital Sander work the same as a PC 7424 XP ?
Thanks,
Steve
The answer to your question is "yes", they work the same way, they just are not as good at maintaining pad rotation under pressure, which is what you want when trying to remove swirls.
I wrote an article just for all the millions of people that still own first generation Porter Cable Polishers, which includes the 7336 and the 7424 models as well as the hundreds of thousands of G100's Meguiar's has sold since the early 1990's.
The short how-to guide for using a DA Polisher
How to maximize the ability of the 1st Generation Porter Cable Dual Action Polishers
This thread also explain exactly where this tool came from and how it works...
The Free Floating Spindle Bearing Assembly - The Story Behind The Story...
Just an excerpt from the above article...
Frustration with clearcoat paints
Now let me tie this back to why machine polishing has become so much more popular since clear coat paints were introduced.
As more and more cars being manufactured made their way into the market, as car owners, or in other words, do-it-yourselfers, would try the traditional methods of removing defects out of the paint, that is with
traditional rubbing and polishing compounds, they would find that most of these products may remove defects but leave their own defects in the paint at the same time.
Not only that, but because generally speaking, modern clear coats are harder than single stage paints, the energy, time and skill required to actually remove defects out of clear coat paints increased dramatically, and in fact increased to the point that many people attempting to remove defects and restore a shine like their car had when they bought it brand new, left most people feeling
frustrated and their cars no better off than when they started and often times worse.
Enter the Porter Cable DA Sander
That's right, I said
sander! The Porter Cable Dual Action Sander is the tool that became the
Tipping Point that was the driving force behind the average person switching from working by hand to working by machine.
The Porter Cable Dual Action Sander with Wood Dust Collecting Attachment for Sanding Wood
Sanding the old finish off using a Porter Cable Dual Action Sander
The exact same tool only outfitted with a foam polishing pad for machine polishing automotive clear coat paints
