Porter cable for wet sanding??
Jrgs-r
Hi guys, I wold like to know if I can use my porter cable for wet sanding, if so what parts do I need to purchse to make it work. Thanks
Check out this thread, it has clickable links to all the part numbers plus tells you how to do it...
Damp-Sanding Tools, Tips and Techniques by Mike Phillips
It's also very thorough...
Safety Precautions with Electric DA Sander/Polishers
If using an electric DA Polisher make sure you have access to a GFI Outlet. A GFI or Ground Fault Interrupter will stop the flow of electricity if it detects a leakage or short in the normal circuit or flow of current.
GFI Outlet
And always wear eye protection and ear protection when using any power tool.
THANKYOU MIKE!!!!!! found what Im looking for....:dblthumb2:
