post polish - pre sealant IPA?????
costo
ok should I use an IPA wipedown after I finish polishing, reading the article by mike it said not to as a stripper but still said to at the end with poilsh? So will it dull the paint???? and what dilution 50/50???? I dont realy want to use a paint cleaner (i have dodo juice lime lite) or would that be better to use? by hand?
sorry I have tried to search but cant find the answers.
Cheers
I have a 32oz spray bottle and I bought the 91% alcohol and only pour 4oz of it in my 32 and the rest is water works great.
Exotic Auto Detail via tapatalk
i use mixing alcohol with water to clean the paint after polishing too.
I spray on MF and just simply wipe off the paint..
Cheers
Once the polishing phase was complete I clean the paint with Isopropyl Alcohol mix just to be sure there were no oils or contaminates left on the surface and this also allowed me to inspect my work.
Some information that you might find useful..
http://www.autogeekonline.net/forum...ow-mix-ipa-inspecting-correction-results.html
:iagree:I always do an final wipe down with a proper IPA solution to inspect my results prior to applying my LSP and to ensure there are no oils left from polishing.
As Mike notes in the above linked article, IPA is a solvent for modern clear coats. That's why it dulls the finish. His recommendation is to use properly diluted IPA (10%) to spot check your correction as you proceed. I imagine what you can do to eliminate any dulling from the spot checks is to make a quick pass with the DA after you do the spot check. Read Mike's article and decide for yourself.
That's a good option, depending upon how D.O. a person is and on this forum that's probably a lot of people. :D
Any dulling won't show up unless you're working on a dark car, it's not that it doesn't happen on a light colored car it's just you're eyes won't see it. You often won't see it on a dark color car unless you use a tape line to differentiate between paint that's been wiped and not wiped, or course it goes without saying that the lubricating agents in most paint care products will darken paint or make the clear layer more clear.
After the last IPA wipe the application of a quality wax or paint sealant should undo any dulling, (seen or unseen), and get you back to where you were. Re-polishing once you confirm to yourself that you've removed the defects and not merely filled them in and also not left behind any machine induced defects is probably the ultimate way to go if your goal is to take your car's paint to it's maximum potential.
I did some testing on black paint last week where I wiped the paint with IPA and a clean microfiber and after I was done I could see marring from the process. IPA can and will soften the top surface of paint a little and it's this softening effect while wiping that creates the potential for marring.
Mike, that's some interesting info. Since you documented that IPA is a solvent for clear coat, I suspected there was really no "absolutely safe" or innocuous dilution. Diluting will only affect the magnitude to which a solvent affects a substrate. The dilute IPA is apparently softening the surface of the clear coat enough that it can be marred. I also wouldn't be surprised if there is light surface smearing from dissolving the surface a bit. Maybe the marring is light enough that it doesn't significantly affect the end results but your test really says it's not good. I guess it was fine for the old solvent-based paints, but not today.
That's some good info Mike. I've personally never had that happen, but I your experience far out weighs mine. So I'll be sure to keep an eye on this and may even stop using an IPA wipe down after polishing and start using a paint cleanser instead.
I use straight 90%+ alcohol on every detail I (and many others) do & I've never seen any dulling or adverse affects unless the paint was super extremely soft(marring). If you're witnessing dulling it's most likely a result of filling which is why you're using IA in the 1st place. I've seen this from M205 from time to time, but never with 85rd.
The important point is that everyone can find the system that works best for them... detailers have their personal recommendations on this topic and chemists have their recommendations.
Since there were no articles on the IPA process anywhere I could find I did some research and did my best to write an article that would help people to at least have a guideline to follow for a safe approach.
I checked with multiple chemist friends, one of which was Dr. David Ghodoussi of Optimum Polymer Technologies, so please, everyone do your own research and come up with the approach that you think works best for you.
Here's two of the articles that came from my research... and in fact I think Dr. David Ghodoussi is going to be drawing from the content of one of these or possibly both to help his customers take a safe approach when using his products.
Miscible and Immiscible - Wax and Paint Sealant Bonding
And here's the one I wrote for using IPA
How to Mix IPA for Inspecting Correction Results
WARNING
Do not chemically strip FRESH PAINT. Fresh paint has not fully cross-linked, dried and hardened. Introducing any type of solvent to the surface and allowing it to dwell could have a negative effect on the paint.
Note: The below article is NOT an official recommendation by Mike Phillips or Autogeek. It is an attempt to clear up any confusion on the topic of chemically stripping paint with the common products used for this procedure as discussed on detailing discussion forums. If you choose to chemically strip your car's paint, or your customer's car paint, all the risk is yours. Anytime you use a new product or procedure, it's a great idea to first test in an inconspicuous area and check the results before moving forward.
Common, easily found options for Isopropyl Alcohol also called IPA
Here are the easiest ways to mix an approximate 10% solution for the most popular concentrations of Isopropyl Alcohol available at the retail level.
91% IPA
To mix a 32 ounce Spray Bottle
Pour 4 ounces or ¼ of a 16 ounce bottle of 91% IPA into a 32 ounce spray bottle and top the rest of the bottle off with water. This will make 32 ounces at 11.375% IPA to Water solution.
70% IPA
8 ounces (or ½ of a 16 ounce bottle) will make 32 ounce of 17.5% IPA to Water solution. Get a 32 ounce container, pour in 8 ounces, (or ½ of a 16 ounce bottle) of the 70% IPA and then fill the rest of the container up with water and you get 32 ounces of 17.5% IPA to Water solution.
50% IPA
8 ounces, (or ½ of a 16 ounce bottle) will make 32 ounces of 12.5% IPA to Water solution. Get a 32 ounce container and pour in 8 ounces, (or ½ of a 16 ounce bottle) of the 50% IPA then fill the container up with water and you get 32 ounces of 12.5% solution.
Why dilute concentrated IPA to an approximate 10% IPA to Water Solution
The most common dilution levels you can purchase over the counter are 70% and 91% Isopropyl Alcohol, sometimes you can find 50% version. At the time I'm writing this article, there are no other articles on this topic to give people a general guideline as to how to dilute and use Isopropyl Alcohol to chemically strip paint. I actually made a post to an AG forum thread where I encouraged someone else to write this article, but to date there's been no takers, so here's my offering.
Most of what I've read are forum members recommending one of two options,
  • Dilute IPA by 50% with water or 1:1
  • Use it straight out of the bottle
Most recommendations I’ve read are:
  • Diluting 91% IPA 1:1 or by 50% with water would give you approximately a 45% dilution of IPA to water solution.
  • Diluting 70% IPA 1:1 or by 50% with water would give you approximately a 35% dilution of IPA to water solution.
  • Diluting 50% IPA 1:1 or by 50% with water would give you approximately a 25% dilution of IPA to water solution.
After talking to my chemist friends, they all felt that these dilution levels were overkill and too strong for removing residues after compounding and/or polishing paint. Most quality name brand compounds and polishes are water soluble and don't need a strong solution of Isopropyl Alcohol to dissolve, emulsify and loosen any leftover residues on the surface.
Their recommendation was for approximately a 10% dilution of IPA to water solution. The reason for this recommendation besides their chemistry background, is that a strong solution of IPA can stain and even soften some clear coat paints.
High Solids Clear Coats paints are "Alcohol Friendly", meaning products like Isopropyl Alcohol, can and will penetrated into, soften, wrinkle and/or stain the paint. To avoid any of these problems, a 10% dilution of IPA to water solution is recommended and adequate to remove any compounding and polishing residues without risking any danger to your car's paint or your customer's car's paint.
Another colleague in the industry coined the term Hot to describe strong solutions of Isopropyl Alcohol used to chemically strip paint.
Hot = How fast a liquid will bite into the paint, the strength of the dilution and the flash time for the liquid to evaporate off the finish.
Full strength IPA is a HOT chemical stripper, the stronger the ratio, the hotter it is.
My colleague agrees with my chemist friends that 50%, 70% and 91% dilution levels are all too strong to safely use to chemically strip paint. This person's recommendation was to stay at or below 25% dilution of IPA to water solution.
For what it's worth...
Pump spray Glass Cleaners have been used for years as a convenient way to strip the finish to inspect correction results, often times because it's a commonly found product in a detailing environment. Most glass cleaners that use alcohol are around the 10% range or lower.
I'm guilty of using IPA straight out of the bottle at all dilution levels, that's because I'm not a chemist, and until I wrote this article and starting speaking with real chemists about this topic, I didn't know the risks involved.
Forum Member Recommendations
Not only have I made the mistake of using IPA straight out of the bottle, I've seen well intentioned forum members on multiple, multiple forums recommend this same practice. I'll step out on a limb here and propose that like me, a lot of forum members are not chemist and have not performed any in-depth research into this topic and their recommendation is just their personal opinion or they are parroting something they read posted by some other forum member that has also likely not performed any in-depth research into this topic.
I don't want to ruffle any feathers, step on any toes or tell anyone they're wrong, so I'm just going to let the information I've shared in this article stand on its own. You, as the reader, can follow the recommendations I've presented or use Isopropyl Alcohol straight out of the bottle. It's your car, (or your customer's car), so do your own research, come to your own conclusion and then do as you will.
My comments...
In the last year, I used some 70% IPA to chemically strip paint while doing some polish comparison testing, and where I had used painter's tape to tape off specific sections for the test, after wiping the area with straight 70% IPA, some of the IPA penetrated between the tape and the paint and dwelled there while I continued testing. When I removed the tape, there was a visible place where the clear coat paint wrinkled-up from too long of exposure to the high concentration of IPA.
In hindsight I should have taken a picture, but I didn't and instead carefully sanded and removed the wrinkle-effect. I did make a post about the experience in an effort to warn others. Here's the link to that thread,
ipa wipedown
Personal Recommendation For IPA
If you want to chemically strip paint to remove any compound or polish residues so that you can accurately see the true condition of the paint after any correction steps, then I recommend using approximately a 10% dilution of IPA to water solution. This is a safe approach to remove any residues masking the true results of your process to the paint without the risk of causing any harm.
You can also opt to use Mineral Spirits instead as they will also remove compounding and polish residues.
Checking Your Test Spot vs Checking the Entire Car
Theoretically, if your use IPA to chemically strip your Test Spot and after stripping and inspecting the results look good to your eyes, then theoretically if you duplicate the same correction process over the rest of the panels you will also remove all the defects and leave the same finish behind that you saw in your Test Spot.
Assuming all the panels have the same type of paint, then you shouldn't have to continue stripping all the paint on each panel, just keep doing the same good work you did for your test spot and trust in your skills and ability.
You can check each square inch as you work around the car to make sure you're doing as good of work over the rest of the car as you did in your test spot, that's an option and choice each person can make. I tend to check my Test Spot and if it looks good then simply repeat the process over the rest of the car and trust in my skill and ability to duplicate my process over and over again with little variation.
Chemically Removing Waxes and/or Paint Sealants
Note this article is addressing the dilution strength for removing compounding and/or polishing lubricating oils sometimes called fillers during the paint correction steps. You can also use this to try to remove any previously applied wax or paint sealant, but while I was speaking with one of my chemists friends about this topic they told me that Isopropyl Alcohol is not effective at removing some polymer products.
Since there's no way of knowing at the molecular level what's on the surface before you wipe, and no way of knowing if 100% of everything has been removed off the surface after you wipe, therefore there's no way of knowing if IPA, (in any form) is effectively removing 100% of any previously applied wax or paint sealant. You can hope... you can assume... but you can't know 100%
If you're dead set on removing any previously applied wax or paint sealant by chemically stripping the paint, then a combination of using both a 10% solution of IPA to Water followed by wiping with Mineral Spirits should remove most, if not all, of any previously applied wax or paint sealant.
Personal Recommendation For Removing Waxes and Paint Sealants
To remove any previously applied wax or paint sealant, I recommend using a light paint cleaner or a light polish applied by hand or machine. A light paint cleaner or abrasive polish will effectively remove any previously applied wax or paint sealant AND leave the paint looking clear and glossy. I call this working forward in the process because the goal is to create beauty.
Chemically stripping the paint will tend to dull the paint; it certainly doesn't increase gloss and clarity. You don't see the dulling effect unless you're working on black paint and repeat the process multiple times. Since not everyone works on black paint, and you're not going to make stripping your car's paint a daily routine, it could be you won't see the dulling effect on your car's paint but it does take place.
Wiping a clear coated black finish over and over and over again with any type of solvent isn't going to make the top clear layer of paint more and more clear, it's going to do the opposite, that is dull it down.
So chemically stripping paint is what I call working backwards in the process. I, personally, prefer to work forwards in all my detailing projects but do understand the reasons why some people want to chemically strip their car's paint, or their customer's car's paint, and each person can decide what the best approach is for their needs.
And again, since you're not chemically stripping the paint as a "practice" but only during a detailing session, the dulling effect is not an issue, but I wanted to point it out just for the most detail oriented detailing enthusiasts or Pro Detailers reading this article.
<End of article>
But yeah, if using 90% works for you I always say,
"Find something you like and use it often"
And while we normally think of this article as it relates to abrading paint, it can also apply to any part of the process...
"Use the least aggressive product to get the job done"
:dblthumb2:
Excellent read Mike! I usually mix my IPA using 6oz of 70% and fill the 32oz sprayed with water. Works good for me.
It’s one thing to take the safe approach when dealing with people that are not well versed with detailing and I respect that. But when that safe road steers in a direction that is irrelevant to common sense minded/experienced (and researched) people we can have a difference in opinion. I too have spoken to Dr. G about the very subject. He is well aware (and has even recommended) the use of alcohol for not only proper surface bonding of his products, but also to inspect the paint after his and other products are used. Again, this may or may not be the SOP that a company that manufacturers or distributes a product may embrace, but that doesn’t mean real world adverse affects will ever occur. Nothing is idiot proof and if you have to cover yourself to relinquish the exposure for liability I fully understand that too. IMHO any softening effect that *could* occur from using IA on paint is only very temporary and will not damage it from my research. I’ve never seen or heard anyone causing damage to their paint from IA. If there are people that can provide this documentation to prove otherwise....I'd love to see it.
The important point is that everyone can find the system that works best for them... detailers have their personal recommendations on this topic and chemists have their recommendations. ,,,,,,,,,,,,,,,,,,,,,,,,,
So I guess just using the cheep dollar store non amonia glass claeaner would be just fine?Personal Recommendation For Removing Waxes and Paint Sealants
Then the Megs Deep Crystal paint cleaner falls into this batch correct?
Thanks
