I also got a pressure washer today
Nice we have that here but not with some of the attachmentsI also got a pressure washer today![]()
Not sure I'll use the attachments. I have a stubby gun and foam cannons already. Will probably also order a new hose and some quick connects.Nice we have that here but not with some of the attachments
Yeah mines just a back up unit because my current one is playing up at the moment.Not sure I'll use the attachments. I have a stubby gun and foam cannons already. Will probably also order a new hose and some quick connects.
That's a great little pressure washer! Upgrade the hose and spray handle most definitely. I went with the Uber flex 3/8 hose and Tutuluck spray wand with all the quick connectors. Only complaint is the 3/8 hose is a pain to drag around because of how much it weighs when full of water.I also got a pressure washer today![]()
I'll probably go with the 1/4" Uber flex. I already have an MTM spray gun.That's a great little pressure washer! Upgrade the hose and spray handle most definitely. I went with the Uber flex 3/8 hose and Tutuluck spray wand with all the quick connectors. Only complaint is the 3/8 hose is a pain to drag around because of how much it weighs when full of water.
I had to go to Bunnings today, so I wondered through the Auto aisle, saw this drying towel for $24.98, feels a lot like a Liquid8r, twisted loop, double sided, and big. Similar sized single sided twisted loop towels in the Auto chain stores are near $50. So I bought one to try out.View attachment 139949
I also saw a hexagonal light kit for $199, I didn't buy one.View attachment 139950
Copy that, was going to run a load through tomorrow.Just make sure you soak and wash that towel before use.
Have you had an opportunity to try the Omnia? Just curious as to your thoughts on it.Omnia is for myself,
Very briefly yes. When i am able to actually spend real time with it and use it to clean more than just a quick test i will report back budHave you had an opportunity to try the Omnia? Just curious as to your thoughts on it.
