Then read the following legendary-tutorial by AGO's Nick for all things Collinite #845!Generally, waxes and sealants only show off the work you done before applying.
If the paint is clean and swirl free, then just about any quality wax or sealant will bring out the gloss in the paint.
Generally, waxes and sealants only show off the work you done before applying. If the paint is clean and swirl free, then just about any quality wax or sealant will bring out the gloss in the paint.
Which would look better on white paint? Menzerna PL or Collinite 845 ?
Also curious which one you guys find sheets water better.
Since the look will be about the same with either, I would definatelly go with PowerLock for ease of application. Just wipe on and wipe off. For Collinite you need to take an Advanced class to apply itI was about to buy some a few weeks back then I started reading about having to heat it up to the right temperature or bagging it on tables until it reached the right consistency... who the heck has time to do that?
One is a sealant and one is a super durable wax--I don't think either are "cosmetic" LSP's. I've never used PL, but I'd wager they will look the same on the car.
As for sheeting/beading, #845 beads/sheets like crazy.
Swissvax glacier
Dodo dw or lf
Bouncers 22
Victoria chaos
Sent from my SCH-I605 using AG Online
