powerwashing rims
krouchchocolate
Is it safe to use the power wash to wash the rims? Will it remove the paint on the rims?
you should be fine as long as you don't stick the gun all the way up to the rim and then there is a chance it would take paint off.
usually you have different heads or a spray pattern. I would never use on the strongest setting and with a direct lazer of water.
I sometimes use my pressure washer on my wheels and in my wheel wells if they are really dirty. Like killr said just adjust the nossel so it's set to a wide spray and not a niddle point or you could take the paint right off with a strong pressure washer.
