Is it necessary? No but why not go ahead and coat it. Most come with a hydrophobic layer. With that said it is not the most hydrophobic which is why most have it coated. PPF specific coatings are designed to be more flexible that a typical coating. Plenty of videos from GTechniq going into detail with their Halo PPF Coating. Avi told me that Cquartz Skin stays flexible over the PPF without hindering any of the PPF's qualities but stated the other Cquartz coatings would be fine to use. The benefit to Skin is how slick it is.
As far as longevity that is going to depend on the manufacturers claims. 10years is about the norm. You are going to have to research the so called "best". XPEL is commonly known. I heard Suntek is better in the aesthetics aspect as it has less orange peel compared to XPEL with comparible results. I believe Esoteric uses this brand.
I’ve never had any of XPEL’s PPF addSo if I have perfectly polished paint (wet
sanded) PPF will add orange peel?
So if I have perfectly polished paint (wet sanded). PPF will add orange peel?
