Mike Phillips
Active member
- Dec 5, 2022
- 51,004
- 6
Pre-Production UDOS Polisher from LC Power Tools - First Look Pictures
What's in the Box
L.C. Power tools has sent out 10 of their pre-production examples of their new UDOS 51e Polisher. The instructions that came with the tool requested me to test in my normal manners and even test in ways I would never recommend to others. Before I put it through testing, and while it's still clean and purdy, I thought I would showcase the pre-production unit and go through all of it's features.
Testing Tool and Pads
Here's everything that came in the box plus a few extra pads I had already received for TV and video work last year.
Assembling the backing plate to the spindle
The tools arrived without the backing plate attached to the tool but it comes with the backing plate, a Hex Head bolt and a Hex Head Wrench.
There's a slotted indent on the back side of the backing plate so when it's attached to the spindle it's locked in place and cannot spin on the spindle freely.
NOTICE the quality in fit and finish of the reciprocating components.
Here you can see that the spindle is machined for the slot on the backing plate to attach.
Hex head wrench and bolt
Carefully ensure the slot in the backing plates fits flush against the spindle before tightening the bolt.
Now that I've attached the backing plate, let's take a look at the tool...
Three Handle Size Options
This tool came with the Medium Sized handle already attached. There are 2 more handles available, a large and a small so you can use the handle that fits your hand and buffing style.
Here's the large and small handles for size reference
Soft Rubber Tool Rests
This is the soft rubber forward tool rest. The tool rest enables you to set the tool upside down and lay flat against a surface without tipping over. These rubber tool rests are soft so they won't scratch most surfaces. They are slow wear items and can wear out but L.C. Power tools designed them in such a way as they can be user-replaced.
Rear Tool Rest
Variable Speed Dial
Speed adjusts from 1 to 5
Air Filter Screens
Speed Trigger
Trigger Lock Button
Stress Relief Cord Support
9' Heavy Gauge Power Cord
The power cord is rubber coated 12 gauge wire cord. The rubber is not only less likely to mar paint but also doesn't have a memory like a vinyl cord so it will relax when used instead of holding a coil.
How much does she weight?
Probably one of the most common questions I hear about the UDOS 51e is how much does it weigh? We have an accurate electronic digital scale for shipping purposes here at Autogeek so let's see what she weighs in at?
9.4 pounds fully dressed
What's in the Box
Rear Tool Rest
Variable Speed Dial
Air Filter Screens
Speed Trigger
Trigger Lock Button
