Evan.J
- Sep 18, 2012
- 4,915
I had the pleasure of detailing this brand new Viper GTS in Stryker Green. This color is a very limited run and only having 33 that will receive the paint.
Upon initial view of this car I found there to be micro marring and holograms all through the paint. I informed the customer of my findings and showed him everything I was seeing.
We made arrangements with the local dealership to have this car sitting on the show room floor while I did the work. I gave this car a foam bath and did my baggie test and sure enough there was able surface contamination. Now, let me say that this car came right from the factory on an inclosed trailer and yet there was still above surface contamination so keep that in mind when you do a new car or have a customer with a new car.
The car was then clayed with the Speedy Prep Towel Fine Grade. After the car was clayed and dried I taped off everything and went to work on the car. I found what worked best was the Rupes Yellow Polishing pad and HD Polish at speed 4. This finished down perfectly and was LSP ready.
After I had done all the polishing Xpel Ultimate was placed over 90% of the car by Adam from Prestige Auto Armor.
The car was then coated with Opti-coat for the maximum protection
Thanks for looking!:dblthumb2:
