how long ago did you wax it with Q2?
I would wait until you get the most out of that wax, unless it is over 3 months
Why waste it if it's not that old in application
I have a new car and I waxed it with Gyeon Q2wax. I want to switch to cancoat, what do I need to do or use to remove the wax so the cancoat bonds?
When I was done playing with Gyeon Wax it came off (surprisingly easily) with Klean-Strip Prep-All which is available at many local auto parts stores; had only been on the hood for 1 or 2 weeks.
The Kleen-Strip? I had a gallon sitting in my garage for 2-3 years. CanCoat can stay good for over a year if sealed well.how long does a can last? does it need to be uses within a certain number of weeks before it goes bad?
You will be tempted to put Gyeon wax over CanCoat. I would advise against it. It is a nice product but it is one of the most regrettable things I did by topping a coating with it. As it starts to degrade it masks the beauty of the coatings hydrophobic behavior.
Stick with a ceramic spray sealant.
once the wax wears off wouldn't the can coat hydrophobic behavior come back?
This would be my vote. Unless you want to polish it off like the Guz mentioned or try nuking it with chemicals like BudgetPlan suggested, I'd just wait it out and try a new product after the current one has worn away.
It should, but it takes a pretty long time to be 100% gone.
wouldn't Gyeon Prep remove the wax?
What if he washed his car with Dawn dish soap? Would that help remove that wax?
The newer Dawn Platinum Plus spray dish soap is the only Dawn I have ever seen that will strip wax that’s not already toasted
