p_bol
- May 10, 2009
- 4
... and would like to run the process I am planning on following by the experts. I recently purchased the Flex 3401 from AG and Meguairs products and will be detailing my 2007 Mazda 6 (cherry mica). It has some swirls and light scratches. I also picked up a 2 x 500 watt work light set from sears. I have all CSS pads: 2 x orange, 2 x white, 2 x gray, 2 x blue, 2 x red, & 1 x wool buffering/polishing.
1) Tape off car with painters tape
2) Wash w/ Meguiars Carwash shampoo and conditioner
3) Clay with Meguiars mild pro & final inspection
4) Start with M205 on gray pad
4a) If M205 does not get the job done go to M105 on orange pad then go back through with M205 on gray pad
4b) If scratches are not removed with either M205 or M105 hit all scratches with Scratch X (the original not 2.0) on white pad
5) Apply M21 on blue pad
6) I believe I read somewhere that M105/M205 combo works well on wheels also. So thinking of giving that a try then coating with Optimum opti-seal
I also have M80 and ultimate compound but plan on using them to maintian the cars exterior after it gets a good one over. I'm planning on spreading the products with the Flex off, then bump to speed 2 - 3 to give a good spread, then work product in on speed 4 - 5.
Any advice/suggestions would be greatly apprecaited. I'd like to ensure I atleast get the process right so I don't spend hours on the vehicle and then get discouraged becasue I did it wrong and have to do it all over again.
:cheers:
:cheers:
