Preserving Opened Bottles of Ceramic Coating
expdetailing
Active member
(Edit: if you know a better way, please share.)
I was researching how to prevent an opened bottle of ceramic coating from going bad or expiring early. Once opened and partially used, more oxygen enters the bottle, which accelerates the degradation of the formula.
During my research, I came across canned argon. Argon is a gas that's 37% heavier than oxygen and is commonly used by wine enthusiasts to preserve opened bottles of wine. The idea is to insert the red straw into the nozzle of the argon can, then place the straw into the ceramic coating bottle. Gently squeeze the trigger for a second or two, then quickly seal the bottle with its cap. That’s the plan, at least.
I had never tried this before—until last night. Time will tell if it works. It should. I don’t see why it wouldn’t.
Canned argon is relatively inexpensive. Although it feels empty when full, rest assured, the can is indeed filled with gas.
I put mine in the freezer. It's a lot simpler.
I've had a 1/4 full bottle of Gyeon Rim in there since before thanksgiving that still looks perfect. No problems except when my kid sprinkled some on his ice cream, but he didn't seem to suffer any ill effects, and you should have seen the beading!
I asked chatgpt how to preserve it, and it mentioned argon. I guess It took me down the long road.
Refrigeration never occurred to me.
Thanks for the tip!
Just watched a video by the Guz and preserving an open bottle of ceramic was part of it. He said he doesn't place open bottles in the freezer as it does not help. What he does do is after securing the cap he spiral wraps the cap and neck m of the bottle with a continuous strip of electrical tape. As I said this was in the video. I'm not a ceramic coating user and don't b know squat about using them.
My bottle of Gyeon Rim mentioned above is still fine.
He probably learned that by studying my content amongst other knowledgeable tips and tricks he shares
The pop tart cabinet is all you need
I think these girls ^^^^^ have something open, but it's not a bottle of ceramic coating.
Ha Pop tart cabinet?
Yes. One of my kitchen cabinets is dedicated to different flavored pop tarts......and of course a opened bottle or 3 of ceramic coatings.
So far, so good...
