I have a 3100 PSI Pressure Washer. I just purchased a Pressure Washer Jet Wash 1/4" Quick Release Adjustable Snow Foam Lance which by the way is $60 off right now with Prime. My question is this. Is the Pressure Washer I have too powerful for the lance? Also, this lance looks like every other one, couldn't find much on it but i bought it anyways. Hope this works! I just want to make sure the pressure washer won't A.) Ruin a cars paint and B.) Work with this foam lance.
Also, this pressure washer has a soap setting on it...if you got to page 16 of the pdf manual it shows the settings. The thing is, this pressure washer has a soap reservoir that uses simple green apc in. Im guessing id have to just put water in there or something so its not mixing car soap and apc or maybe it will work without anything in the reservoir on the "soap setting". Any input would be nice.
