oneheadlite
- Aug 20, 2015
- 1,791
- 94
Hey Gang
Looking to replace my 5+ year old baby Ryobi (baby like it's just a lil guy, not that it's a prized possession! 1600/1.2gpm). Trying to decide what route to go. Use will largely be split between pressure washing the house and car use (pre rinses, foam cannon work, etc).
Obviously anything is an upgrade from what I've got right now. To be perfectly honest, not having had a pressure washer before I've been happy with the lil Ryobi. For doing the house they make a 16' extendable setup that makes it so I can do the whole house without having to clamber around on a ladder, so if I went super high output I could see that turning into quite the workout.
While I'm a buy-right-buy-once guy, I'm trying to keep it under $400. Also needs to be a 15amp unit - the wiring was very poorly thought through at my house and on top of barely having any outlets in the garage/outside they're all 15 amp. Doing the outside of the house I end up having to move the unit around a bunch and make use of both hose spigots outside. Side note, I'm not currently in the market for changing hoses, so I'd like to stick with the M22/M14 connections to be able to use my extension hose.
Originally I was leaning towards getting the 2300psi 1.5gpm AR Blueclean Maxx from Griot's. I know you can get it for a few bucks cheaper through other means, but I've had such positive experiences with their customer service I figured I'd go through them. They've got their whole lifetime guarantee thing; though full disclaimer I totally understand that a Pressure Washer has wear and tear written all over it, so my expectations are realistic.
It's hard not to look at the Active V2 unit with the higher GPM. Has anyone seen/heard how the newer gen is holding up? I thought I had read the first gen had various issues that killed my interest in it.
Any other washers out there worth taking a look at?
Thanks all for their input.
