Pressure washer pump replacement
swan
Not sure where I should post this but my pump broke the other day and after looking around on the web I can't replace the bearings that broke as the main part I need is almost 3/4 the price of a replacement pump.
I am going to buy an oil filled replacement so this won't happen again, but this is what I am really after. Can I replace my pump with a higher psi pump or no? I have a 5.5hp honda pressure washer if that helps answer my question. Right now it is 2450 psi.
After not finding an answer to my question all over the web, I figured why not ask fellow detailers that use pressure washers all the time.
