Pressure Washer Question...
tmurph01
Starting to put together my mobile trailer and had a question concerning the pressure washer.
I will be using a stand alone water tank that will feed a pressure washer. Now, I have read that I should add a water pump in line before the pressure washer to protect and prime the line. Now, I know there are self-priming / pumping. If I use one of these, I shouldn't have a need for a separate pump.. correct?
Would this work in this case?
Champion Power Equipment™ 1.8 GPM PortableGas Pressure Washer, 1,700 PSI, CARB Compliant - Tractor Supply Co.
I am trying to figure out my best set-up for this without using a separate water pump. Thanks!
