I'm' looking to pick up a foam cannon for my pressure washer. It's a Dewalt 3100DPD gas unit that produces 3100 PSI and uses 2.8 gallons/min. My question is in 2 parts...
first, what kind of quick connect should I order with the cannon? the closest one I can see on the ordering page where you choose your QC is the kranzie fitting, and that's only because it looks like the screw fitting on the end of my lance extension. Every other fitting on the unit is NPT but I don't see that as an option on the ordering page. I have extra NPT fittings so should I just use my own? Here are pics of the quick connect and lance on my unit:
my second question is which foam cannon has everyone had the best luck with? the one sold on AG is made of brass but only has a max pressure of 2600 PSI. I suppose I could bring the rpm's down on the PW to accommodate that. The cam spray unit, on the other hand can handle 3000 PSI which almost matches my washer. Big problem with the cam spray is finding one in stock.
Any insight would be greatly appreciated.
thanks in advance.
thanks in advance.
