Pressure washer wall mount station 2.0
Daviddear30
Pressure washer wall station 2.0
I built this old pressure washer wall mount in 2018
Time for an upgrade
Rebuilding and redesigned.
All made from 1 sheet of nice 3/4 plywood
Adding room for a master blaster revolution car dryer with 35 foot hose and hose reel
Adding a hose hanger for the 50 ft expanding hose. Used to fill buckets and final flood rinse after washing cars
This one will be painted vs stained
Gray color with a faux marble style finish then clear coat. Practice piece sprayed over white in pictures.
Added a backer to bring the hose reel forward a bit more for the master blaster hose
Coat of paint #1
Coat 2
Coat 3
Stone spray dusting from high up
Clear coat
Sent from my SM-N986U using Tapatalk
Almost finished
Nice set up. Looks to make washing and drying en easy proposition. Do you wash in your garage?
Definitely
I took down the old one to add more
So quick to get started and put away afterwards
Buckets parked
98% finished
