It just occurred to me that if you use a pressure washer to wash the car, that`s about 2500 or more will it have a negative effect on the wax/sealer, could the pressure remove some of the wax/sealant?
That amount of psi can remove your paint if you use the wrong tip and get too close. 1000 to 1500 psi with a wide angle tip is the most you need to detail a car.
Derrick
