SRHTX
- Mar 16, 2009
- 1,666
Hey Everyone,
Well, this is a test using the new Optimum Hyper Polish Spray. All I can say is, this polish spray ROCKS!!!!! It's very easy to use. Just make sure you have plenty of towls around. The Polish Spray really does not throw dust around and I mean hardly no dust what so every. If you are using a new pad, like I was, that is what will be around on the vehicle. All you will have to do is spray one ot two shots onto the pad. You will not need to spray it onto the vehicle. I ran the pad over the vehicle twice in each area. It the vehicle has any marks/scratches, just push a little harder for a little more time and it will be removed. The Camero had a few scratches on it and the 3 I found came out with just a little extra bush with my Flex. I set the speed, using the Flex, at 4 and never changed the speed. I did not need to clay this vehicle since it has been on the lot for less than a month. There were some ruff areas but, I did not clay them. The dealership rinsed off the car before I took it home and the vehicle gathers dust in rought to my place which is a little over a mile away. After I did a very quick Optimum NRW, I Spray Polished it. After the polish was done, I used the DP Max Wax to finish her off. I wanted to seal it with Optimum Opti-Seal but, I gave them the chance to use thier product to buyers who wanted a perm sealant. This dealership uses Zymol Sealant.
Anyways, here is that the Camero looked like in the begining:
