Prism Detailing - Bentley Supersports Correction Detail (protected with Swissvax Crystal Rock)
PrismDetailing
Hope everyone does mind me posting some previous details, the weather is soo bad here, i cant see much work for a while, seems like a have a lot of jobs stacking up :(
Anyway this job was carried out for a customer who was looking for a Swissvax detail. Also wanting certain scratches removed or dulled down.
Car as i turned up:
Some of the stratches
Started by rinsing the car to remove any loose dirt/dust then cleaned the alloys, tyres, arches and engine bay with APC/Wheel cleaner:
Rinsed the areas worked on then Snowfoamed the car:
Rinsed again the washed with Swissvax Car Bath:
Rinsed again then detarred with Autosmart Tardis, rinsed, Clayed with Swissvax Paint Rubber, rinsed:
then some spot areas worked with Iron Cut and again rinsed, then washed again, rinsed and dried with car dryer from carwashnwax.
At this point the engine bay was treated to Swissvax Motorshine:
Then onto the correction.....
some swirled pics:
Took paint depth readings averaging:
So I used the following products:
Silverline rotary
Kestral DA
Chemical Guy Hex Pads (white/orange/black/red)
3M FCP, Ultrafina
Menz Powergloss, Power Finish, Final Finish
Megs 105/205
Swissvax Cleaner Fluid Pro
Each panel was treated differently as each panel reacted different to each product and there was not a consitant combination over the whole car, but was definately the most challenging correction to date...
50/50 during correction:
corrected:
once the correction was completed, then applied Swissvax Cleaner Fluid to paintwork and alloys, then buffed off then on the paint work applied Swissvax Crystal Rock and Autobahn to the alloys and Pneu to the tyres:
At this point i finished for the day leaving the Crystal rock to cure over night.
Back the next morning, and removed the cured Crystal Rock and Autobahn, left to air for 15 mins then applied the second coat of Crystal Rock to the paint work and left again. whilst curing I cleaned the exhaust tail pipes with Swissvax Metal Polish and ultrafine steel wool:
Any plastic trim on the exterior was treated with Swissvax Nano Express, the rubbers round the windows and door seales treated to Swissvax Seal Feed, the windows treated to Swissvax Crystal.
Interior was treated with Swissvax leather cleaner and Alcanta cleaner inc seats, door cards, dash, then protected with 303 Fabric Protectant. hoovered out and Swissvax Mirage applied to door shuts and carbon fibre inside the car. The metal door plates treated with Brillant products and all hoovered out.
The finished product:
Some reflection shots:
Thanks for viewing
Robert
Prism Detailing
Prism Detailing - Car Detailing Specialist
FB: PrismDetailingUK
Nice job! Look forward to you sharing some more of your work!
I like the oil cap! Nice work!
It's funny how the different panels reacted so differentlty. Did the owner confirm a repaint?
The owner(s), one is a famous singer (in the uk not sure anywhere else) and the other a famous football (soccer) player, I think money was no object for them and whatever needed done to the car was done, as for resprayed ? I could have been but there was not indication from the owner if this was the case or not. They were just looking for the end results.
What i did find interesting, he had a pot of Swissvax Crystal Rock, he had nearly finished a 200ml pot with only 6 applications to the car by hand.....yes only 6 ! ! ! ! (you might be suprised by that, but to this day even i am, works out on average £100 ($166) per application)
Bentleys have top quality Duco. I would be surprised if it needed to be resprayed.
