Pro Blend Bottle Proportioner - Another Review
swanicyouth
I'm always amazed at how two people can have opposite experiences with the same product. After reading Sonic's interesting recent review of the PBBP (gallon size) I decided to check out my own and see how it's doing a year after I bought it.
While I never had the issue of it going "crooked" or leaking, I wanted to recheck its accuracy. I bought this product probably a year ago and have used it only with a gallon of Meg's APC+. It's never been removed or cleaned.
I decided to top of my spray bottle of APC + 1:4. It looks like there is about 18 oz in the bottle:
I know those spray bottles are about 1,000 mls when full so:
1000ml - 535ml(~ 18oz) = 465 ml.
Since the dilution is 1:4 (5 total parts) then I knew I would add about 3oz of APC+ and 12oz of water to fill the bottle to the approximate dilution.
First I dial the proportioner to 90 mls.
I've noticed when using this you want to dial it so the green line is right under your required volume, not the line at the top of the liquid after its full (like image shows).
Then, squeeze bottle to fill proportioner:
Pull back and hold proportioner cap:
Since I was testing the accuracy of this unit, I decided to pour it in to a 3oz measuring cup first. This worked out well, because I needed exactly 3oz. It was kind of hard though to pour into the little cup with one hand accurately and take a picture with the other hand.
Empty cup showing its 3oz when full:
Start by slowly tilting the bottle while holding the cap back with the same hand (normally I would use 2 hands):
When the proportioner got low enough, I even held the whole gallon of APC+ upside down with the proportioner's lid off to get every drop of the 3oz out of the measuring chamber:
As you can see, for me, the bottle didn't just "keep on pouring" or leak. In fact, it measured quite accurately:
I was able to use the one year old proportioner with no drips, no mess, in an accurate manner. Here is a picture of the area wear I poured the APC+, you can see nothing spilled due to the action of the proportioner:
Note: if you examine the pictures close enough, you will see a tiny bit of spilled APC+ in front of the measuring cup in the "while pouring" picture. This was no fault of the proportioner, as I spilled maybe a 1/2 ml due to my hand shaking while trying to pour into the little cup while juggling my IPhone trying to take a picture. Normally, I would dispense directly into the bottle (via a funnel) and use 2 hands.
Thanks for looking.
Thanks for sharing this. I bought mine a few yrs ago and forgot I even had them. I guess now I have no excuse for not using them.
Next up: Ebay Crayola Gallon Dispenser Pump $4.99 delivered:
Could it be that the older models work fine...I have 2 that are at least 3 years old and work great.
I have multiple in both the gallon and quart sizes and have never experienced a problem with any of them.
Was contemplating buying a couple of these but saw bad reviews, thanks for the review OP, my mind is changed. Will definitely include some in my next order.
I have had no problems with the 32 oz size. I have 5 or 6.
I have new ones that work fine so far. I am getting curious if it is actually the pick up tube not being cut that is causing some of the problems. Do you remember if you cut the tubes??
It's been a while, but I'm guessing I cut the tube. If it was too long, I would have cut it, not just bend it in the bottle.
Sorry I can't remember what I had for lunch, much less what I did to the tube 3 years ago. LOL!
LOL I'm right there with ya! Doesn't seem like it would make much difference, but the cup was bent over pretty badly in Son1c's picture.
glad yours works well, maybe mine is a defect?
Could be. There is a certain percentage of any manufactured product that is going to be defective. Hope the new one Meghan said she was going to send you works.
As mentioned I bought two of these to try out.
So far I've used it on Megs Wheel Brightener and followed OP's method and it worked exactly as described!
No spills what so ever with accurate measurements. No more wasted/spilled product.
Will order more for my other gallon bottles.
I also use the pump dispenser sold my AG on CG Maxi Suds II and I don't have any issues with it either.
