Shade Tree
- Feb 3, 2010
- 594
If one of our elite AGO crew members would please chime in here .......... :dblthumb2:
Recently the foam cannon has lost pressure to the point of little more than a garden hose would push. I traced the problem to the AG Foam Cannon assembly itself as the original pressure washer assembly flows perfectly.
I took as much of the assembly apart as possible and still can not seem to get the fixture to work properly. When the cannon is not used for a few seconds and then released the water pressure is fine, but quickly seems to trickle to free flowing. Doesn't matter if soap bottle is being used or not.
The pressure washer, as I mentioned, works flawlessly without the foam cannon in place. I'm guessing something within the foam cannon assembly isn't opening/working properly.
Please let me know what to do on my end in having this exchanged. I'll post pictures of the piece in question (it's basically what the foam cannon is without the bottle) if need be.
Thanks.
Thanks.
