Mods, not sure where this belongs. Feel free to move this.
This week I tried to restore a headlamp. 2005 Sienna, never done this before, so I used toothpaste, and then after rinsing it off, sprayed on some coats of clear coat. On one side, it worked fine. On the other headlamp, I sprayed too much clear coat and saw it run down. Now this is where things went sour. I decided to use a cotton swab to dab up the runny clear coat. I succeeded in pushing a bunch of white gunk all over the headlight. That was yesterday.
This morning, I've been using 400 grit sandpaper with a very liberal amount of water (on the sandpaper, as well as on the plastic headlamp itself). I do see some white, milky goo in the water that runs off (which I can only imagine must be bits of the clear coat). But I'm not sure its making it any better. In a Chris Fix video I saw him recommend a possible second attempt at the 400, before moving on to higher grit levels. I've now done this at least 3 times (wet down the lamp & paper, and gently, using circular motions, sanding away that top layer on top of the headlight). There appears to be fewer white streaks, like I saw before, but it does appear to be more cloudy all over the light cover.
I'd hate to just do this interminably, and end up putting lots of scratches into the plastic light cover.
Should I move to a higher grit? I also bought a 2000 grit paper. My hesitation to use that, however, is that if a rougher sandpaper can't pick it up, why would a smoother paper do it?
