Mike@DedicatedPerfection
- Feb 26, 2011
- 12,365
PRODUCT REVIEW: Kärcher underbody cleaner
Introduction:
As you drive your vehicle down the road an accumulation of debris will collect on the bottom side of your vehicle whether it be dirt, sand, salt, etc. Over time this buildup of contamination will start to break down the materials underneath your vehicle and start to form rust if left alone.
Product Description:
Highly effective chassis cleaner for removing dirt, mud, sludge, sand and encrusted salt. The Chassis Cleaner is designed to reach the underside of vehicles and remove corrosive sediments deposited over time. A build-up of salt, oil and mud can cause severe long term damage to any vehicle if left untreated. The Chassis Cleaner employs dual upward facing spray nozzles which spin at high speed and safely loosens and blasts dirt and grime.
Product Details:
Construction: Solid plastic
Directions: Easy to use
Color: Black
Pricing: Varies from vendor
Pressure: Can withstand 2300psi
Water Temp: Can withstand 140 degrees
• Cleans the underside of your vehicle
• Lightweight for easy maneuverability
• Height adjustable head for all types of vehicles
• Foam nozzle to create a lather of detergent on you vehicle
• On board storage for the lances
Directions:
Attach to Kärcher quick disconnect wand
Turn water and Kärcher pressure washer on
Pull trigger on wand and maneuver underbody cleaner around the undercarriage
Follow up with foam attachment nozzle to add undercarriage protection
(video borrowed for demonstration purposes)
[ame]www.youtube.com/watch?v=FttzfyvXWVs[/video]
PROS:
Allows you to precisely clean the undercarriage where a your pressure wand cannot reach
Foam nozzle attachment allows you to spray an undercarriage protectant
CONS:
Added step to your wash procedure
Introduction:
Product Details:
Color: Black
Directions:
PROS:
CONS:
