Product Review: Liquid Natty Blue
TroyScherer
http://www.autogeekonline.net/forum/product-reviews/27760-product-review-liquid-natty-blue.html
Initial Product Observations After Opening The Box:
- Slightly odd blue color. (Robins Egg Blue?) I expected it to be more the color of the regular Natty Blue.
- Nice bubble gum scent. No hint of chemical undertone.
- Seemed thin compared to other liquid waxes like Megs NXT 2.0. But not water thin.
- I was unsure how it would be to apply it by a buffer as it was so thin. I choose to apply it by hand for now.
1st Experience:
- Approx. 8:00 pm in the evening
- It was easy to apply as it was a thinner than other liquid waxes. I like this. But at the same time it was easy to apply it a little heavy.
- In the areas where I applied to thick it was harder to take off. I had to rub with some firm pressure to get it off. I didn’t care for this.
- The overall look was good. There was no real difference in the look of the car compared to the wax that I had on it previously. (Megs NXT 2.0) The LNB gave the car a good depth and shine.
Current Test Vehicle:
1. Washed and dried the vehicle. Car was very dirty so it looked ok prior to this application of LNB.
2. I decided to put LNB to the test as it claims it can be used in direct sunlight and on a hot vehicle. I went ahead and pulled the car out into the sun and left it sit there for 30min.
3. I applied LNB using a clean yellow foam applicator.
4. After applying I went inside and had lunch for 1 hr before removal. I wanted to see have the heat and sun would affect the wax and it removal.
5. Buffed off wax and admired my work.
Pics From Test:
LNB Seperation After a Week of Sitting
Car Pre LNB
Car with LNB Curing
Car Port LNB
Notes From Test:
- LNB was very easy to apply
- This time I made sure to apply a very thin even coat.
- It started to haze almost immediately.
- The LNB was very easy to buff off.
- It seamed as thought the heat and sun actually aided in the curing and removal process.
- Car looks very good with the new coat of LNB.
- There is no noticeable muting of the flake. In fact I think that the really stand out nicely when look for them.
- The next morning the LNB felt nice and slick for a Nuba. Not as slick as a Menz Power Lock but I don’t expect a Nuba based wax to get that slick.
- It felt almost liberating to apply wax and buff it off in the sun. A definite change to the usual wash; and pull the car into the garage and stay there all day.
Future Plans:
- I want to test the durability of the LNB and do a standard maintenance was on it every week. I hope to get 4 – 6 weeks out of an application of this here in Ohio.
- I would like to retry applying LNB in the shade on a cool vehicle to see it the 1st attempt was simply my error in application or if it needs some heat to aid in the removal process.
- I am trying to line up my Sister-in-laws Black Saab as another test subject for this wax.
Final Thoughts:
Overall this wax seems to be a winner. I will hold out a full judgment until I can test durability and Beading/Sheeting. I enjoyed the fact that I was able to apply this out in direct sunlight. This fact in itself could make it a very good wax for a mobile detailer that is stuck out in the sun and heat. Based on future pricing it could very well fall into price category that is saturated with OTC waxes. This would not be a bad thing in my opinion as being able to use this in direct sunlight and the overall final look would easily push it to the top of my list in this category.
Nice review Troy, :xyxthumbs: :dblthumb2: :xyxthumbs: it's great that many of our observations are falling in line with each other.
My only difference was I thought it actually hard to over-apply. It was so runny compared to usual liquid waxes that I was especially extra careful in application.
Why can't I find this on the AG store??? Am I blind?
12 AutoGeeks were selected to be the beta testers of the product, it's not for sale.
So the good news is you are not blind .... bad news is you have to wait to test out this great product. It's worth the wait.
Thanks for the great review Troy!
Application by machine is a breeze. Goes a very long way and since its a liquid its easy to get it on the pad.
Did you find it to be " smudgy" I have issue snow with natty's blue paste now not removing very well... It's very easy to get smears that look like halograms but also that buff out with a MF.. almost like its not fully curing on the paint or something?
glad to hear I am not blind :) I was holding out on the natty's blue paste.
I found that when first applying LNB after putting on the Applicator it was easy to let it a little heavy. I fixed this by working it into the area I was applying it to like I would with my PCxp. I was trying to see if a simple one pass application would result in a nice thin coat as the LNB was thinner than most of my liquid waxes.
I didn't have any problems with it being "smudgy" this time. I as able to apply it really thin and the heat from having the car outside really help to cure the product.
Week 1 - Wash
I was able to wash my car on Saturday which is 1 week after the original application of LNB. There is only 1 coat of LNB so this will be a good test for durability I think.
I have assembled a few beading pics for you enjoyment. :detailer:
Drivers Side C-Pillar:
Drivers Side Rear-Quarter Panel:
Hood:
After the first week the LNB has held up well. The looks are the same as the day I applied it. The feel is still fairly slick. It definitely feels like a standard nuba wax. I will try and wash it again in another week or so and post up my findings.
Any questions are welcome.
Update Time:
It has now been 4 weeks since my application of LNB onto my car. On the horizontal surface there is still a very nice beading as well a sheeting when using the flooding method for rinse the car after my wash. On the lower vertical surfaces it looks to me as LNB is starting to loose the fight. The gloss and depth that was originally there has started to fade slightly and dirt has started to cling a little bit more. This is my DD and I drive on rural back roads to work so I do tend to accumulate a little more dirt and grim than normal. I only expect to get 4-6 weeks out of a nuba wax on my car in these conditions. So LNB has at least made it to my baseline expected duration.
Rear Spoiler Beading:
Roof Beading:
Roof After Sheeting:
