Product Review: Meguiar's D143 Wheel AND Tire Cleaner
With Meguiar’s offering a concentrated wheel and tire cleaner I was a bit eager to try it and give it a review. This is a product that is placed in Meguiar’s Detailer line and as such I feel it designed with production based detailing in mind just like it concentrate detailer brothers such as D151, D156, and the like. This product calls for a 1:1 or 2:1 dilution ratios. I have not tried out the 2:1 dilution ratio however a product being marketed towards the production based detailing world I feel the stronger dilution of 1:1 being ideal. After all, in the production based world cars usually are more neglected than the occasional garage queen and the stronger ratio is a must to help cut through the grime.
Even though I have not used the lighter dilution of 2:1 this product feels like it has ample power to cut through moderately dirty wheels such as the daily drivers with annual wheel cleanings while offering tire cleaning capability.
http://www.autogeek.net/meguiars-non-acid-wheel-and-tire-cleaner-d-14301.html
PROS:
· Effective wheel AND tire cleaner in the fast paced production based detailing world.
· Not as aggressive to user or wheels as Meguiar’s Wheel Brightener
· Can be diluted to either ratio depending on severity of wheel/tire
Cons:
· Won’t completely remove brown tire staining
· Won’t clear up heavily soiled wheels
Impressions: What’s nice about this product is you can cover the wheel and tire simultaneously with a generous amount and the tires start to bleed brown within a few seconds of application. The directions call to let the product soak up to 30 seconds before agitation. Within 20 seconds I began to clean the wheels with various brushes while the tires bled brown. When the wheel was agitated I moved on to the tire with a tire brush and began to scrub the tire. When the cycle was completed I rinsed the wheel/tire down to inspect the results. On this vehicle the wheels/tires were severely neglected and required a second round to get them 75%. After completing the second round of wheel/tire cleanings the wheel still had a good bit of contamination as well as the tire had a very faint brown hazing.
To really get these wheels back to where they need to be a dedicated contamination removing product is needed. In this case CarPro Trix was used. CarPro Trix is formulated to remove iron and tar in one step allowing you to remove these contaminates. What’s more is that Trix is safe to use not only on wheels, but paint and glass as well.
http://www.autogeek.net/carpro-trix-tar-iron-remover.html
After two rounds of cleaning
Time to break out CarPro Trix!
Trix just sprayed on
Look at those runs!
Within a few minutes just before agitation
After agitation
Just before rinse off
Completed
Just how wheels should look!
Mike
Excellent helpful review of the meguiars d143 wheel cleaner they look brand new
Great review on both products, great work as well. Even products being good, what impresses me more are your photo skills ;)
Thanks for sharing,
Best Wishes.
Excellent review and great write up Mike! Thanks for sharing your findings.
Would you say that it's really acid free and safe for the wheel finish? The consumer counterpart of this seems harsh on the wheel finish.
Doesn't seem like it's very effective in cleaning baked on brake dust.
Thanks for the kind words James!
Thanks for sharing,
Best Wishes.
Thank you Rafael!
I try to incorporate my DSLR into my work as much as possible.
Thanks Marc!
As for the Chemistry of what's in this product I would have to look it up. On the bottle it mentions "Non Acid".
As far as I know the consumer version is this. Correct me if i'm wrong.
Meguiars Hot Rims All Wheel & Tire Cleaner, cleaner for factory wheels
For the brake dust, I would say there was a good amount of tar built up on the wheels. When Trix was applied most of the sections bled brown while few areas bled purple. Iron-X would have told the full story of what was what.
Hi Mike...
Thanks for this review of a Meguiar's product.
And as Marc has noted:
^^^:iagree:^^^ :props:
Hi Marc...
Here's the MSDS:
-seems to have more alkaline ingredients than acid ingredients {pH 13.5 :eek:};
http://www.meguiars.com/content/en/msds/D143 MSDS.pdf
-and the product description doesn't list "safe on bare aluminum" (as one of the wheel finishes).
"Meguiars Non-Acid Wheel Cleaner is safe and effective on":
•Clear coated wheels
•Factory painted wheels
•Chrome wheels
If you don't care:
What is the consumer version?
Since brake dust is baked-on (sintered?) in layers...
It may take multiple applications to remove all of it? :dunno:
Nice review. I use this as my wheel and tire cleaner and have been happy with it. Removes old tire dressings. I typically do it 2-3 times per tire. I'm using it at 3:1 right now and it still works good. I do agree that something else is needed for baked on brake dust.
Add a tire scrubbing brush for your DA to your arsenal...no more scrubbing multiple times.
I have the blue, which is softer than the black and allows me to run it right up to the rim/wheel.
Just today I used D143 for the first time as well. I think it is a great value for maintenance washing so that you are not constantly using up your higher-end, more powerful wheel cleaners. I loved how it started cleaning the tires immediately after applying.
Glad to find this review as I just ate some clear coat off my wheels today with a degreaser that was diluted too strong I was using on my tires. Now I need new center caps and my wheel look kinda ugly now.
Guess I will learn
Excellent review and thanks for sharing Mike :dblthumb2:
Excellent review Mike! I have often wondered about this product
Thank you Andrew!
Honestly this product offers tremendous bang for the buck and I am going to start using it as my maintenance cleaner on my BMW's and save Trix and the like for quarterly cleanings.
Hi Mike...
Hi Bob! Thanks!
Hope you enjoyed the review.
Thanks for the detailed feedback on this product.
Thank you sir!
I feel the same for heavy contamination.
I have the complete Mother's brush line up including the tire brush as well as the Daytona brushes. These were used in the review.
I agree. It's not necessary to use a high end wheel cleaner every time. Also love the fact that it cleans the tires as well.
Guess I will learn
Ouch! Remember to start with the least aggressive route.
Thanks James!
Just bought this product and am anxious to try it.
What is everyone's preferred dilution for regular washes/cleaning?
Do you use it it at higher dilution for deep cleaning or switch to other strong wheel cleaners for such?
Thanks.
Congrats!
Thanks.
If using as a wheel cleaner for your personal vehicles then the lighter dilution is fine. If using in other situations for dirty wheels then the stronger dilution is recommended.
