Mike@DedicatedPerfection
- Feb 26, 2011
- 12,365
PRODUCT REVIEW: Pinnacle Black Label Diamond Paint Coating v2
Introduction:
I have reviewed the first generation v1 coating upon release. With that out of the way this is the second-generation product with more updates to the product that provides better water beading characteristics throughout the life of the coating and longer working time to return a better user experience when applying to your paint.
Product Description:
Pinnacle Black Label Diamond Paint Coating is a ceramic coating that creates an extremely glossy, impenetrable layer of protection on your vehicle’s paint. Formulated using the most advanced nano-glass ceramic particles available in a paint coating, Diamond Paint Coating shields your vehicle against UV rays, airborne contaminants, dirt, acid rain, road salt, and other common pollutants that attack your vehicle on a regular basis. Spray and wipe application lasts up to 3 years!
Product Details:
Black Label Diamond Paint Coating with its nano-glass formula is resistant to alkaline cleaners, degreasers, and harsh detergents. Compared to your clear coat, Diamond Paint Coating is more resistant to scratches and marring. The nano-glass formula forms such a hard shell of protection that virtually nothing can penetrate or stick to it, making your vehicle retain that just-detailed shine for years!
Another advantage to Black Label Diamond Paint Coating is the self-cleaning effect that it provides. The nano-glass formula fills in the microscopic pits, pores, and valleys of your vehicle’s paint, creating a perfectly smooth, flat surface. Dirt and road grime will be removed with virtually no effort, making your vehicle easier to clean and maintain.
Directions:
1. Ensure surface is cool to the touch and out of direct sunlight.
2. Place your hand in a plastic sandwich baggy and feel the paint. If it feels rough or gritty, use Pinnacle Ultra Poly Clay.
3. Polish the surface using Black Label Surface Cleansing Polish. This step is crucial as it removes polishing oils that would otherwise prevent the coating from properly bonding.
4. Working one panel at a time, spray Diamond Paint Coating directly onto the paint and evenly distribute using a Lake Country Coating Applicator.
5. Work the coating into the paint until it disappears.
If high spots occur, lightly buff with a Gold Plush Microfiber Towel.
PROS:
Relatively easy to apply
Pump mist applicator gives user control of product
Leveled fairly easy with mf towel within short time
CONS:
Flashed too quickly IME
[ame]www.youtube.com/watch?v=flwBh6zz_5M[/video]
Conclusion:
This coating returned ease of use while spreading out however I experienced a pretty quick flash rate with it. I was able to work an entire panel such as the front fender as in my video however when I was finished spreading the product I had to immediately grab the mf towel and begin to level the coating to return the results of a coating without leaving high spots behind. I would say there was a 30-45 second flash time before the product would become very difficult to level out.
It was rather warm where I was working and this could have had the effect on the application that I experienced. Once I got all my ducks in a row and began systematically working on a shorter time frame between application and wipe off I was greeted with an overall better application process with excellent results.
Pinnacle Black Label Surface Cleansing Polish
:buffing:
Introduction:
Product Details:
Directions:
PROS:
CONS:
Conclusion:
:buffing:
