Product to use to remove compound/polish
Frank70
Did my first attempt at paint correction (just the hood) and I failed to cover the windshield wipers. Got some compound/polish on them. What would be a good
product to use to remove the white. :thankyousign:
Quick detailer and microfiber towel or a magic eraser
Sent from my SM-G955U using Tapatalk
Buster906 - thanks for the info. I will try in the morning. I have both handy.
The best bet is water after you do a panel.
You would be surprised how good it removes polishing residue if it is fresh.
Once it has dried well multiple products to try.
What I do is after a panel I wipe with cloth then hose off (if possible) and no problems.
Water will require less cleanup than any cleaner and it is virtually free.
Any waterless wash diluted at a higher strength will clean the panel from the Polish and prep it for a coating and remove any trace polish residue
Meguiar's D114 and McKee's N914 work well to remove compound and polish residue. I use both at 1:128 and it doesn't take much - oftentimes a quick spritz is aid enough to remove residual product. ONR at 1:128 works too, but it lacks the sort of "bite" produced by the other options.
Spray way glass cleaner foam.Spray or drench then toothbrush all the compound out.Or a pressure washer with a low psi.
Try to remove asap. The sooner the better.
Optimun no rinse wash O&R.
Thanks everyone for the replies. I have a few things to buy and try now.
