Products safe to use on coated car?
NikonGuy
Ok, my car is coated with CQuartz
Are these products safe to use and won't strip coating? I'm thinking yes they are safe but just want to be sure
Iron-X?
Nanoskin clay substitute bar?
Clay?
Eraser?
Thanks
IronX is the preferred method to decon, I'd suggest adding CarPro Reset and/or CarPro IronX Snow Soap...
Iron-X?
Clay?
Eraser?
Thanks
None of those options will outright remove the CQuartz, but just like a clearcoat, the Nanoskin pad or clay could induce some marring into the coating.
Make sure you've allowed the coating to fully cure before you start using the harsher chemicals.
Iron-X and Reset are what you want to use on a car that has been coated
