Proper engine detailing techniques
gr82bhum
How do most of you detail under the hood? What products have you tried? :rolleyes:
:) i have tried several products but found none that does what it says. simple green so far has been my favorite. i try to cover what looks to be electrical and open air intakes,using a low pressure (household faucet) with a fire dept. type nozzle for the different spray patterns,and a long reach soft brush. still looking for better products all the time which is the reason i joined this web-site!
I like to use DP Exterior Surface Cleaner in one of our foam guns. I cover the electronics (alternator, battery, MSD ignition, etc) with plastic bags, rinse everything, soak all areas with the Gilmour foam gun....then I let it sit for a bit and settle in. After that, I hose everything down and rinse it real good. I then start the engine, let it idle for a bit, dry out the excess water and dress all plastic/rubber.
A Lot Of Windex, Chrome Polish and lots of Q-Tips -- and a lot time!!
:D :D
Wow...now THAT is cool. :D
You should post up more pics of the car in the Show N' Shine forum!
APC diluted 3:1, soak, scrub, rinse. repeat if necessary. I havent found dirt or grime that has stood up to that. Nevr_Dull on the metal, and 303 on the plastic/rubber.
