After some searching I didn't find much on the technique for applying glaze. I have the XMT glaze, and previously the couple times I used it I assumed it was like applying wax so I put it on at around speed 3, and moved the pc quite fast with no pressure. Well, the other day I actually was reading the bottle, and saw it contains cleaners and to apply no faster than 5500 opms. So that made me question how this should be applied. So how do you do it? Should pressure be applied, and what about speed and number of the passes? I just finished up using it on one of my cars last night, and I had the PC at speed 5, and made two (one vertical, one horizontal) moderate passes (maybe 4-5 inches per sec?) with light pressure.
