Proper use of Megs #205
rjgervacio
Is this polish meant to be used by section only where there are light scratches and swirls, and plus as a finishing polish after using a Megs #105 (or other similar polish)?
Or can I use this on the entire car as an overall finishing polish to bring out the car's shine before waxing it?
Also, what would be the ideal Lake Country buffing pad to use with this? CCS White?Im the MAN
You use it like M105 except it is less aggressive.
You use it after M105 to take out the haze or you can use it if you car just needs a touch up.
Depending on the scratches you could use it with orange or white.
Oh so that means it's only sectional then where correction is needed. I thought I needed to polish the entire car before moving on to the next step. If that's the case, what would be next step? Waxing?
There are no hard fast rules to this and many times I'll correct each panel separately.
Meguiar's M105 - Compound
Meguiar's M205 - Polish
I always do a test spot starting off with a less aggressive to determine whether or not I need something with a bit more muscle to remove the defects adequately.
After polishing you can apply a sealant and stop here or like many apply a coat of wax on top of the sealant to give it added depth and protection.
Basic steps in order
  • Wash
  • Clay
  • Compound
  • Polish
  • Sealant
  • Wax
M205 can be used to remove light swirls and add some gloss back to the paint. Depending on the car your working on it may have great correcting abilities or it may not do much other than add some gloss back to the paint.
When I polish out a car I will start with my test spot as BobbyG mentioned. Do all of my steps there first (say M105, M205, a finer polish if needed, then wash/dry, then wax/sealant). After I am happy with my test spot I will then tackle the rest of the car doing one step at a time. So, I'd hit the whole car with M105. Then hit the whole car with M205, and so on. You have to always work in small roughly 2x2 sections to ensure you are getting good results. If you work too big of an area when you are correcting your not going to get the results your looking for and it doesn't allow the polish and machine your using to really do the job well. Always work small if you can. In the end it will save you time.
This is great and correct info, but want to add that after you have polished your panel using the method above, I always like to do a (for lack of a better term) panel pass. This is where you would polish the whole panel (if it's a fender or half of he hood) in one section. This blends all of the polishing you've just done together.
So say your fender is 4x4. Your first polishing step would be to break it into 2 2x2 sections, then after that, make a couple passes on the entire fender so that now you are doing the 4x4 section. His will help you get complete and even coverage.
The m205 has beautiful working time so it will allow you to do this. Use light pressure and set your PC to about 3.5 or your rotary on it's lowest setting with slow arm speed. Generally speaking.
I get the idea of test spotting and working in small areas at a time, say 2x2. In fact, that's actually how I'm going to be working on my car.
The part which I wish to clarify was, would it be necessary or better yet safe to use Megs #205 on the rest of the car even if it doesn't have any defects on it but just to achieve a glossy look prior to waxing?
You can safely do it, but realize that M205 does have some cutting ability. But if you use say a White LC pad and M205 on the rest of the car you should get great results.
You could also look into maybe a finer polish like Menzerna PO85rd for something like this. It's a very fine polish.
Yes! Now this is the kind of opinion I was hoping to see. Thanks SeaJay!
I'm aware of its cutting ability (I think it scores around 4 based on its packaging). I don't have the Menzerna P085rd but I have the Megs #7 Showcar Glaze. I also have a Grey and Blue LC pads. How do you suggest working with them in terms of pairing it with the polishes that I have. Probably something like:
  • White - Megs #205
  • Grey - Megs #205 / Megs #7
  • Blue - Collinite 845
  • White - Megs #205
I honestly would probably go White - M205 I've had good results with this combo, then go to your Blue and Collinite. This will depend on how the paint reacts though. M205 can leave some tick marks from your DA if the paint is really soft. If you end up with a marred finish or your not happy, try following it up with your grey pad and M205. Might help.
If the car is is good condition then you don't need to use a glaze. A glaze will basically help hide the minor swirls that are in the paint but glaze doesn't tend to last very long. I personally don't like using glaze much, but there is a place for it in the detailing world.
Here is a compound chart to give you the comparison of where the polishes you have fall.
Autogeek Swirl Removers & Compounds Comparison Chart
Thanks for the tip! I've seen that chart before actually and I used it as a guide to determine the polishes that I would be purchasing. I wish there's a chart also that has some sort of matching with a buffing pad.
If these are the only things you have at your disposal, and you are wanting to keep it to a 1 step.
I would honestly suggest to just try the white and grey with the 205. Its hard to give specific suggestion without knowing the paint.
I would lay down a tape line on the hood. On one side try the white and on the other try the black. This will give you a very nice comarison between the two. Depending on the paint, I really think there will be such subtle difference between the two in terms of corrction and this will be the best way to check the results against each other.
Rule of thumb says to always go least aggresive first then bump it up. But in this case niether of the two are very aggresive and I think the differences will be subtle, not doing them side by side will be hard to gauge. If you end up going with white, you will bring down the grey side to match, and if you go with grey, you will just further refine the white side.
M07 has no cut. It is a pure glaze and only contains oils. You could apply this after your polishing step to fill in and hide the deeper defects the polishing step did not remove. I would use this with the softer pad of which ever you have left after polishing. So if you used white, use grey with M07, f you used grey, then use blue with m07. You may have to seal by hand.
There isn't a chart that gives you what pad to use with what polish because really you can use any pad with any polish. Different combos give you different results.
There is this chart that gives you how the different pads align.
http://www.autogeekonline.net/forum/product-charts-graphs/21155-pad-comparison-chart.html
