Hello AGO,
I'm looking at purchasing a prosumer grade electric power washer to compliment the new shop I'm moving into. I really don't want to have a "gas vs electric" debate (I have a honda powered 2700psi unit at home which works great- no denying this will be more powerful). Electric makes sense for this shop. Also, I understand the "box store" units make sense to a lot of us on this forum for their relative effectiveness and cost for performance, but I want something that I'm using 5 years down the road- industrial build.
I'm also thinking that 120v makes the most sense as well (which will limit my max psi/gpm). I have 20A receptacles as well- no problem there. The "hottest" the input water will be is ~130 degF.
The three units I've been considering are:
1. AR630-TSS-HOT, 2.1gpm and 1900psi, AR triplex pump. auto on/off with trigger pull. ~$770
2. Northern Tool NorthStar 1573011. 2000psi and 1.5gpm. Leeson motor and CAT pump. Rollcart ~$680
3. Mi-T-M 1500psi, 2.0gpm, AR direct drive pump, rollcart. msrp $1100, found a "new" one on CL for $750
My initial top contender is the AR630 because of the size (more compact), the highest "cleaning units" of the bunch, Hot water capable (up to 180 degrees), and the TSS system engages the pump only when the trigger of the gun is pulled (the other two run continuously). I've spent a little bit of time with this unit in the past and it has plenty of power for detailing needs! I also like the adjustable nozzle on the end of the wand. No cart included so I would either need to build one, or mount it semi-permanently in the shop.
The NorthStar caught my attention because of the Leeson motor and CAT pump combo- both high quality companies from the USA. I also like the fact that it has a roll cart with a place to put coiled cord and hose. One notable drawback would be the overall size (compared to the AR) and the inability to take "hot" water, but again, it looks like its built like a tank and would last for many years.
The Mi-T-M unit looks great as well- I have similar feelings for this one and the NorthStar- size might be an issue, but looks to be built like a tank (another USA company). AR direct drive pump also gives it additional brownie points.
Sorry this post is long- any feedback or suggestions would be appreciated!
