Pump for 10 litres container
Dannyk
Been purchasing the 10 litre size containers recently and wondered what pump you use for transferring to a smaller container?
Try a janitorial supply store.
There is a boat load of different sized pumps out there, just a bit tricky to locate them locally.
Where are you located?
Bill
Thanks for the response, we have one in our area which is in Berks Co. Pa. which i'll check out, never know what one may find in stores of that nature.
I get 5 gallon containers of some products, you can get a spigot for those, not sure if your 10 liter containers are set up for that, but it's pretty effective and uses good old gravity.
picture.php
I didn't find one on AG's page with a quick search, but I think I've seen them here before. If you have a local detail chemical distributor, they should be able to get them for you, or the janitorial supply that Bill mentioned.
