I typically use it under the hood and will dilute it and use it on rubber floor mats (if really greasy). It works great for me.I don't see anyone talk about Purple Power here. Do you guys not like this product? I love it, as it's very cheap and works great. Should I not be using this on my vehicles?
I use it all the time and have for years and have never had 1 problem out of it. I generally mix it 50/50 unless somethings really nasty then I go full force
I saw a guy over at Autopia Forums say he uses it to strip paint off cars before painting![]()
Is it paint safe?
Thank you, Flash.
I HATE LOVE BUGS!
I am not as daring as crownkote to use Purple Power on the interior. For carpets, Folex works great. After reading the AG forum, I thought I would give Folex a try...glad I did. It works great. I only use it as a spray. I also use 303 on the carpet and use it in my little green pro.How does it work on carpets in comparison to something like Megs APC+? I have purple power but I use it on tires, wheel wells, and engines. Never tried it on anything on the interior since i haven't really needed anything stronger than Megs APC+, but it is cheaper than the Megs and I can get it at advance auto for under $5/gallon with coupns and stuff.
I recently stopped using it on tires and wheels because I was told that one of the chemicals in it will dry and rot tires.
