I would not use an APC for stripping wax. Griots makes a surface prep spray. If you are going to polish you do not need to strip the paint. You can also use a paint work cleanser that will remove wax and sealants.
Since there is such a variety of plastics used in automotive applications...Anyone know if a 10 to 1 dilution of purple power and some elbow grease will be strong enough to remove some wax from the plastic trim on my exterior?
I would recommend 0:0. That is, do not use it on paint.
OP is asking about trim
