rossnroller
- Jan 15, 2012
- 6
HI folks
I have a white Ford Focus LX, which is not garaged and has to suffer through the extreme UV radiation of a Perth summer. To do the best for the car's protection, I bought some Collinite 476S and 845.
I washed and claybarred before applying 2 layers of Collinite 476S. I intend to apply one more coat of 476S before finishing off with an application of Collinite 845 (which I understand is especially designed to afford UV protection).
My questions:
1. Should I claybar again before applying the 845, or will this remove the current layers of 476S? Or, is it simply unnecessary, since I used the claybar within the last two weeks, and immediately after applied the 476S? (For the second application, I only washed and dried the car - didn't claybar - and was intending only to wash and dry before applying the last coating of 476S).
2. How long after the application of the final coating of 476S should I wait before washing the car again and applying the 845?
3. Is there anything to be gained by applying a second coat of 845 soon after the first? If so, I assume I don't need to claybar, and do need to wash and dry immediately beforehand, as with the 476S?
Look forward to some advice from folk who are more informed on this stuff than I am - that throws it wide open!
Cheers
My questions:
Cheers
