EXOv2 can be over coated with other products but please note that if done you will get the surface performance of this product rather than those of EXOv2
Per the Gtechniq website:
If you use it before EXO application, you will reduce the bonding potential of EXO. You can wash with UWW+, but you'll want to make sure to strip every layer of wax/sealant and use Panel Wipe before.
I suspect using it as a means of keeping your car clean after EXOv2 application is going to have minimal impact on the performance of EXOv2 since it's not like you're layering a true wax or sealant.
UWW+ is actually a waterless wash and does not change the beading or sheeting of EXOv2. Other QD that are more "waxy" might change the sheeting, but will quickly wear off.
I would leave the EXOv2 alone. The hydrophobic qualities are simply off the charts.
