Question about Gyeon Wetcoat on wheels...
joebruin77
Member
Hey everyone,
I read several posts on this forum recommending Gyeon Wetcoat on wheels. I just used Wetcoat for the first time on the wheels on my wife's Mustang Mach E and was impressed. Super easy and quick to apply. While I love the look of the wheels, they are a lot of work to keep clean. I hoping that the Wetcoat will make it easier for me to clean them.
My question is, this car sits outside 24-7 and often in direct sunlight. How long can I expect Wetcoat to last? How often do I need to reapply it?
Many thanks,
Joe
I've used Wet Coat quite a bit and it's a great product. I would use it on wheels every other wash. It won't stand up to the heat generated by the brakes, but it helps make cleaning easier.
You can buy the concentrate of Wet Coat called Essence. Carpro Hydro2 lite I think is an even better value.
I use it every couple months, in between I do a rinseless on them. I have Carpro Hydr02, gyeon wet coat, and BF hydroseal on the shelf, I use them interchangeably and don’t find any difference between them. They all work well. I Spray on, hard hose off….dry with leaf blower….
Using a spray sealant often tends to attract more dirt than using it every few weeks. Just my experience.
Just use the drying aid you use to top off.
Nanoskin Super Charger in the 1:100 gallon concentrate is the leader of value if you’re willing to make a large up front purchase. Otherwise, like Glen E said, they’re all similar so buy the best value.
I was using Poorboys Wheel Sealant until I learnt about Carpro Hydr02. Having to deal with the Mustang PP1 wheels was a full-time job as it was, a spray and rinse product was a game changer for me. The only thing I missed was the smell of the Poorboys.
Have been using Hydr02 Concentrate and Gyeon Wet Coat ever since.
It's even good on mowers too.......
In terms of protection and making wheels easier to clean, I think these products do achieve that in a limited way. As mentioned, the heat in these areas will reduce it's lifespan, but application is so easy that it can be topped up ever months or two. As much as anything, I find having these products on wheels makes them easier to blow dry after the wash.
Hey everyone,
Many thanks,
Joe
Wetcoat, as a sprayable application, won't last long at all. If you wash the vehicle once a week it will help. If you wash your vehicle every other week, or every 3 weeks or once a month then you'll want to consider are a more durable form of protection. A good ceramic coating (like Carpro Dlux or Gyeon Rim) would be the way to go.
Sio2 spray n rinse products are really only great for instant water beading after washing to make drying easier.
^ I have found this to be true. Glorified rinse aid IMO. Nothing more. Will protect for a few weeks only if you don't use a contact wash. Contact washes usually kill the spray/rinse sealants.
…in fact Gyeon told me that Wet Coat doesn’t offer UV or oxidation protection which I found surprising considering Carpro states that their hydro2 does.
How does Carpro Hydro2 compare to Mckees37 Hydro Blue?
They're all so similar IMO. I never had any issues with any of them.
In reading reviews of them last week, Gyeon Wetcoat seems to get ever so slightly better reviews than the others but they’re more similar than they are different.
I agree. I will say that Wet Coat worked flawlessly for me. Never had any streaking issues at all. Too soon to tell yet with the hydro2 I'm using.
I plan on applying Cancoat Evo to the entire car in a couple weeks. Can I just apply Cancoat Evo to the wheels as well, or should I buy Gyeon Rim for the wheels?
If it makes a difference, this is an electric car, so there is very little brake dust.
I would just apply Can Coat Evo. Curious what others think though. :)
Can Coat on wheels with periodic Wet Coat after washes should work well.
Hi everyone - new here - I had a question for people using WetCoat on their wheels:
- At what stage of your detail do you apply the WetCoat?
- If I do a spray and rinse, does this impact the application of a tire dressing at the next step or does it just not bond to the rubber and washes off?
For example, if I want to integrate this step into my routine this is what I would be doing:
- Washing wheels and rims
- Foam entire car
- Full rinse
- Contact wash
- Full rinse
- This is where I would apply WetCoat to the rims
- Rinse wheels
- Dry car
- Apply LSP
- Apply Tire Dressing
- Enjoy
Any thoughts?
Any good spray sealant is going to make wheel maintenance a breeze. Once that foundation is on, it will just take soap to clean the wheels. I have mine coated with TWHS SC. Maintain them with TWHS WW.
Just wanted to follow up with my experience putting Gyeon WetCoat on the wheels using the steps I described above. As I suspected, the WetCoat did impact my ability to apply a dressing to the tires afterwards. See picture below - I washed the car as usual, applied WetCoat to the wheels, rinsed off, went about drying off and waxing the car and then applied Chemical Guys VRP to the tires themselves.
This dressing has worked well for me in the past, leaving a nice dark tire for at least a week or two - very consistent coloration as well. Not this time! You can see where the WetCoat has presumable added some hydrophobicity or protection to the tires themselves creating an uneven application of the tire dressing.
Timeframe was - washed the car in the morning, went for a long drive (Around 700km), and noticed the odd pattern when I arrived at my destination and took a picture.
I'm unsure what I can do to change my process - maybe apply the WetCoat using a microfiber instead, to prevent it from spraying on to the tires themselves? This might be a skip for me for the wheels at least.
I've never had bonding issues with tire dressing after applying these spray-n-rinse products to wheels (currently using Nanoskin Super-Charger). And I'm not even careful when I spray.
You could focus your mist to the inner parts of the wheels and less around the edges. You don't need to DOUSE the wheel or cover every square inch of it. If you are then your spraying too much. Just a couple mists over the face and barrel and rinse.
Or you could apply Wetcoat as you normally would and then go back to the tire with a scrub brush with a spritz of tire cleaner (sprayed on the brush) and do a light agitation of the tire for a quick once or twice around. This would remove the residual.
